How was the old road via the airstrip? Would you recommend it to get from North Gate to Khwai community camp?
Answer:
At the moment there are no issues using the old track with slight deviations, I have attached a google earth with drop pins so if you open your google earth and zoom in you will see the required track. Fortunately I got to know this area well over the years and have never used the transit road, there are always options as new diversion tracks have been created. There is one channel of water about 12km heading north from the village that needs to be negotiated.
This crossing is facing south so if you are outbound from the Kkwai village take the crossing to the right, it is about head light depth. If it doesnt look good then there is a crossing about 50 m west which is wheel depth, failing that back track slightly and head for the Khwai river and there is a mere puddle crossing about 100m from the main channel. There so many little tracks that will bring you back to the main track.
Once back on the main track continue to the pin and turn right, follow the via points on the track, go through two open areas and take this shallow crossing, turn immediately right after the crossing and head back to the main track which will take you along the Khwai river to the community camp area and on to Savuti if required.
Final drop pin shallow crossing.
This may sound like a mission but this is the current well used route and the only deviation from the airstrip track. Bare in mind that the transit road will be used more and therefore reported on, but is far less scenic
source: Andy - 4x4community
